Question about getting new setup to the dyno?
Old 06-23-2008, 03:16 PM
SPRAYED 01's Avatar
Default Question about getting new setup to the dyno?
So this weekend im swapping out my pte67mm for the new tc78,swapping the high impedence 60lb injectors for some seimen 83lb low impedance with a driver. I need to get it to the dyno which is going to be about 50miles away.
What should i do to drive it out there? Can i just lower my fuel pressure and set it using the wideband? Obviously im not going to beat on it at all,but i dont want to have to get it towed.
Alex
Old 06-23-2008, 04:15 PM
Sideways240sx's Avatar
i dont know if the the car will run/idle going from 60 to 83 pound injectors.. Depending on your tuner you might be able to run up there with your pcm, have them flash it with a super safe tune that you can get the car there. Other then that.. maybe swap out turbo, go really easy on it, stay out of boost, and then swap injectors in his parking lot, should take you under 30 mintues to do them.
Chris
Old 06-23-2008, 04:28 PM
SPRAYED 01's Avatar
Thats a good point with the injectors but how will it run with the versafueler wired up?
Old 06-23-2008, 04:31 PM
6 Second Club Moderator
LASTLS1's Avatar
Alex
I don't think so.
Old 06-23-2008, 09:30 PM
SStolen's Avatar
Alex, how much power are you going for??
Old 06-23-2008, 10:44 PM
theblur98ss's Avatar
I'd try to trailor it or even rent one from u haul. That's a little bit of modding to be driving that far.
Old 06-23-2008, 11:17 PM
SPRAYED 01's Avatar
Id be really happy with 625whp. Its going through a 9inch and an unlocked converter so i have a lot of drivetrain to push through. Im also switching to e-85 so im thinking my goals are possible.
I can rent a u haul and pull it with my Jeep. I just really wanted to fire it up also just to make sure i dont have any wierd leaks,bleed the coolant and a few other things before the dyno.
Old 06-24-2008, 05:06 AM
EPP
EPP's Avatar
You could always leave the old injectors in there and not completely hook up the driver until you get where you are tuning it. We have people do that all the time when they are coming to our shop to get their cars tuned. Bob
Old 06-24-2008, 07:48 AM
SPRAYED 01's Avatar
I didnt think you could half install the driver.
Old 06-24-2008, 07:52 AM
No Juice's Avatar
What about the high imp RC75's injectors? I would think those would be enough, maybe not?
Old 06-24-2008, 08:07 AM
Dumb Ass Vette Moderator
ls1290's Avatar
I would first try putting back the older injectors and remove the converter box temporarily. If you ware not willing to do that, they I would trailer it down.
Keith
Old 06-24-2008, 08:39 AM
SPRAYED 01's Avatar
I havent wired the box in yet.I think what ill do is install the turbo first,drive it around and make sure everything is still okay,(coolant,exhaust leaks).Ill put like 20 miles on it.
Then ill install the the driver and injectors and trailor it over.
Old 06-24-2008, 09:01 AM
Rhythm's Avatar
Just out of curiosity, did you receive the TC78 yet? I'm waiting on mine...
Old 06-24-2008, 09:03 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
When you have a price on the trailor rental pm me and I'll give you my flat bed buddy's number, price might be pretty close.
Old 06-24-2008, 09:24 AM
SPRAYED 01's Avatar
I have not received it yet. I call turbonectics yesterday and they said by friday.
PSJ,
I was just going to rent a dolly and pull it with my Grand Cherokee
Old 06-24-2008, 09:50 AM
black98ws6ta's Avatar
If you got the versafuler it has a bypass so to speak built into the harness. It has male and female connectors built into each side (computer and engine side). Leave the old injectors in it and drive it to the dyno. At the dyno throw the injectors and hook up the harness so it goes through the versafueler.
Quick Reply: Question about getting new setup to the dyno?
