Pontiac Trans Am Oil Pressure Problem
Old 06-23-2008, 04:54 PM
jzilinkas's Avatar
Default Pontiac Trans Am Oil Pressure Problem
Hi all. I own a 2000 Trans Am. I just changed the oil a couple of weeks ago, using synthetic oil, as I have always done in the past. Now the oil pressure gauge keeps going up and down at odd intervals. I don't want to ruin the engine but this is my primary source of transportation. I'm hoping it is just the gauge that needs to be replaced. Any thoughts? Thanks!
Old 06-24-2008, 08:45 AM
NC01TA's Avatar
Probably no responses because it is too serious to contemplate. The last thing you want to do is guess wrong! I strongly suggest a trusted professional mechanic or the local Chevy or Pontiac dealer unless you are really good at analyzing things for yourself. Hopefully it is just a gauge issue.
Old 06-24-2008, 08:57 PM
myws61's Avatar
How low is it going and how high is it going? Where does it sit at idle? And is it stock? Does it go up as the rpms go up?
Old 06-24-2008, 09:31 PM
TRlGGER's Avatar
+2 Only mine has a rough idle when the oil gauge goes down. Does yours do that too?
Old 06-24-2008, 09:51 PM
IRONFIST's Avatar
Low oil pressure can destroy your engine. Take that car into a mechanic ASAP
Old 06-24-2008, 11:25 PM
myws61's Avatar
if its below 30 then yes take it in. 40 is the halfway mark.
Old 06-25-2008, 04:44 PM
TRlGGER's Avatar
Wouldnt it set off a code? i mean id hate to go the dealer and pay 90$ just so they tell me "Its Normal" or the ever popular "You know.... Its not a new car".
Quick Reply: Pontiac Trans Am Oil Pressure Problem
