Need help with head decision.
Ok so the pockets on my 98 heads are factory fucked. Low seat pressure resulted in cam failure stock.
Machine shop shimmed a couple springs and they only came up to 100 lbs seat pressure, they're rated at 125 IIRC (comp 918)
Should I:
A) run em
B) try to find a set of heads cheap
C) machine a set of 5.3 truck heads to work (not sure of this cost)
or any other options?
Should I:
A) run em
member has 2000 heads for $75 plus shipping, I have some valve covers...
machine shop labor to finish shimming will be close to that I'm sure and I'll have subpar seat pressure, correct?
cam is a TR230 imitation, and I don't want to half *** this to the point I can't rev to at least 6500 safely because of shitty top end issues, what do you guys think?
LS1Tech Premium Sponsor
I have a used set of PRC ported 5.3l stage 2.5 heads for $800 with springs or $600 without springs!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
