will this give me at least 400 rwhp/rwtq
i am researching for a cam soon and most say of my buiddies say that i should get the tr224
i dont want a cam that peaks at 6400, i want usable power between 2500-6500
my main goal is to have a 400+ in tq and horse power, while keeping my tq slightly higher than my hp
i have everything down to what i am going to buy BUT the cam
what i have now
Hooker Longtubes
Hooker ORY
Corsa Cat-back
LID
here is my list of the for sures
FAST 92 intake
FAST 92 TB
TSP stage 2.5 5.3 heads
ls6 ported oil pump
ls2 double roller timing chain
edit: thinking about adding some 1.85 rockers, what would be the lift of the tr224 on with these??
i want to have a 112
and what does the +2 after the lsa mean
any other cam selections??
what i have now
Hooker Longtubes
Hooker ORY
Corsa Cat-back
LID
FAST 92 intake
FAST 92 TB
ls6 ported oil pump
found this on youtube and its exactly what i want
http://www.youtube.com/watch?v=7dYEl98ZQiw
and he has the same mods that im going to get
yay me.
yay me.
With those supporting mods, and that cam, yes, you should be over the 400rwhp/rwtq mark, BUT, you will have more hp than tq. After you swap out the stock camshaft, your hp will be higher than your torque in a NA setup. Spray that bitch if you want more tq than hp
The +2 means the cam has 2 degrees of advance ground into it.
Other cam selections you ask? Yes, I'd go bigger, but that's me. For a great all around cam though, what you've decided on will be nice. If you are set on the 224/224, I'd get the XER grind vs the TR grind. It has a bit more aggressive lobes and a bit more lift. Hey, every little bit helps, right?
what i have now
Hooker Longtubes
Hooker ORY
Corsa Cat-back
LID
FAST 92 intake
FAST 92 TB
TSP stage 1.5 5.3 heads
ls6 ported oil pump
what i have now
Hooker Longtubes
Hooker ORY
Corsa Cat-back
LID
FAST 92 intake
FAST 92 TB
ls6 ported oil pump
jk man...i think with heads and cam you'll clear the 400 hump
thx guys
i was looking at TSP packages and the offer the 224r, what are the benefits of the 224r and the tr224
http://www.texas-speed.com/shop/item...d=203&catid=15
and good call on the XER 224, im going to research that.
steppin up now! (that cam) the intake with the exhaust will really help you out.. get that thing breathin. I woundn't go to high on lift with out changin valvetrain. I'm sure you have realized you will need to change valvesprings but if i were going with much lift at all I would insist on lifters. (i know from experience ) Looks like you are going to put some heads on probably so the lifter thing will be accounted for when ya do that.. just dont forget your lifter trays... they are like 8 bucks a pair (there are 4 trays total) if you didn't know. not worth losin a motor over vavle/lifter issues.
If you are interested in just breakin 400 i have two sets of heads, some springs (never used), and head bolts you might be interested in. Either way, your mods look like you are thinkin good balanced motor and are headed the right way. Sorry if you knew all of this stuff. I didn't kno all of this when i started? good luck bud.
thx guys
224r = .581
tr224 = .563
so the 224r has a little bit more of an aggressive ramp rate...
I wouldn't bother with those 1.85 rockers. The 224 cam will give you a nice power curve across the whole board, but I would go with something slightly bigger. I am running a 226/232 cam with xfi lobes which nets lift at .609/.604 on a 111+1. I swapped this cam in place of my T-rex that was gonna go into the motor.
If you were to run this same cam with the rest of the mods you have listed, you should see a really nice outcome and a broad power range.
Yea there is no doubt in my mind after reading on here that you will be in the 400 range easy.
On top of that a lot of people are liking the 224. Sure you could go bigger no problem, but people run good times with the 224. Like someone else said, if you want more torque than hp, then you will need to spray it. I think you'll be over 400 without the fast intake and tb.
can't run higher ratio rockers with most aftermarket cams...the lobes are too agressive.
so forget those.
but if you wanted to calculate lift
[(specified lift)/1.7] x (new rocker ratio)
so if the cam has .563 lift
.563/1.7 = .33118
.33118 x 1.85 = .613" lift
so forget those.
.563/1.7 = .33118
Instead of going with different ratio rockers, just get a cam with the desired lift. I added 1.8's because the I wanted some more lift after I already had my cam installed. My lift was .566/.568 (XE high rise lobes), so I threw on 1.8's to get me to .599/.601, plus I needed to upgrade my pushrods, so while I was in there it made sense to do the rockers. Since you are still choosing parts, I would just make sure your lift is high enough. Oh, I am a DD BTW.
