Need help with transbrake wiring on Edelbrock 71900 controller (I searched)
Ok I looked around and I noticed the Edelbrock controller isn't very popular. Either way I have it hooked up VERBATIM how they want it hooked up without a transbrake. Well now I am putting in the TH400 with a brake. Here is the diagram I went by to install my nitrous:
http://static.summitracing.com/globa...itrouscont.pdf
The wiring diagram is on page 13 of the PDF. Now it shows the wiring with a transbrake. The thing is I have to rewire half of my damn setup. Right now my setup is wired to the top diagram "Typical Progressive Controller Wiring Diagram". Is there any easy way to splice into my current setup so that I don't have to rewire everything. I hid alot of wires and it really is alot of stuff to take a apart.
Any help is greatly appreciated.
8 SEC SLOPPY SHOT!!!
Make sure your factory defults are set right also.I had some issues with mine as it was dumping fuel while the nos selonid was progressing.I belive some of the controllers that were sold had the wrong defult settings.If you go on yellowbullit message board you will find in the nitrous fourm a post i did about problems with my progressive controller, sj pointed me in the right direction.
