Fueling & Injection - RaceTronix hot wire and Pump.
1LastTime 69
06-24-2008, 10:19 AM
Thinking of installin a walbro and hotwire kit.. i knw the tank doesnt have to be dropped for the pump. but does it have to be for the wiring kit?! and do u have to run the wires all the way up to the motor?
I can really drop my catback cus its all welded up..
anyhelp here guys thanks.
ZL1Killa
06-24-2008, 11:33 AM
are you complaining about working on your car?
are you installing the walbro inside or outside the tank?
as far as i know you have to drop the tank or do the trap door method...which i prefer not to cut my car
you can drop the tank on jackstands in an hour easily...EASILY... its not as big a deal as everyone makes it.
why is your entire catback welded?
Nasty N8
06-24-2008, 12:27 PM
Not only that you can get your catback down enough with the rear dropped if it is still clamped at the Y. and you will need to clean ou the gunk from the tank while it is out.
Nate
1LastTime 69
06-24-2008, 12:57 PM
well the dumbass who had the car before me had the hooker all welded up... i dont mind cuttin the trap door as long as i can run the hotwire kit by doing this as well or do u NEED to drop the tank.?
2000Firehawk
07-01-2008, 09:42 AM
http://www.racetronix.com/RX-F98-FPKG-2.html
http://www.racetronix.com/product/RX-F99-FPKG-2/RX-F99-FPWHG-2.jpg
By looking at the pics , I don't think so..
or call a dealer an ask...:)
thunder racing = 1-877-516-7223
lmspeed = 260-724-7792
extrememotorsports = 480-517-4969
AFASTYZFR1
07-01-2008, 10:59 AM
I ran my hotwire kit without dropping tank
jomomma
07-01-2008, 09:04 PM
me too. i taped the weather pak connecter to a coat hanger and pulled it through! sounds crazy, but it works.
robsquikz28
07-01-2008, 09:45 PM
have to drop the tank and for ur exhaust cut it reweld it or just clamp together. as for the harness you do not have to drop tank u can either run it under ur car or just cut holes in the car and run it that way to the alternator. its easy
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
