Lights Not Working
Old 06-24-2008, 11:02 AM
Topless TA's Avatar
Default Lights Not Working
I have a 98' Trans Am Convertible
and the interior lights dont work at all
including the dome lights
wont work via door unlocking,
wont work via door opening
map lights are the same however wont work even with the switch
I have pulled the fuses and swapped with other ones and no luck
checked the bulbs with the exception of the maps lights
any ideas or places to start?
driving me CRAZY
thanks in advance..........
Old 07-01-2008, 02:58 AM
98boxer's Avatar
heres a link that might help
https://ls1tech.com/forums/showpost....18&postcount=7
Old 07-01-2008, 09:14 AM
Topless TA's Avatar
thanks 98boxer appreciate the link,
good read, but my issue is internal lighting in the compartment
cheers
Old 03-27-2009, 01:09 PM
Topless TA's Avatar
still fighting this
Old 04-23-2009, 09:18 PM
Topless TA's Avatar
Buller...
Old 04-23-2009, 10:09 PM
transambandit's Avatar
check under the dash and see if one of the grounds is loose.
Old 04-24-2009, 08:14 AM
Topless TA's Avatar
First piece of helpful advise i have had... THANKS!
can you tell me where the ground is located under the dash?
sincerely appreciate the help.
Old 04-24-2009, 11:25 AM
when you pull the kick panel off you if you look near the top of the dash near the fuse panel you should see it, its a black wire and a bolt going into the frame.
Old 04-24-2009, 11:29 AM
Topless TA's Avatar
AWESOME....... i will check it out tonight
thanks 1,000,000
Old 04-24-2009, 12:57 PM
Flaring Afro's Avatar
someone said a while ago they replaced the rear bumper and this happened. some short around the bumper.did they ever work? what have you done recently?
Old 04-24-2009, 01:15 PM
that is true, when i was vht-ing my taillights one of the bulbs ended up becoming loose and it caused the tailights and gauge cluster to go out, might want to check your taillights also, but then again it was because of a blown fuse and if he checked all the fuses then who knows. OP you checked both the fuses under the dash and under the hood right?
