lq4/lq9 6.0 crankshaft/block identification (need help quick please!)
Old 06-24-2008, 12:43 PM
jmm98LS1's Avatar
Default lq4/lq9 6.0 crankshaft/block identification (need help quick please!)
I need to know if there's a way to visually identify a lq4/lq9 6.0 liter crankshaft or block. I'm about to buy a 6.0 shortblock and the seller doesn't know what year it's from. I need a 01+ for what I'm wanting to do, so I'd like to verify I'm not buying an older block that I can't use. Thanks!!
Old 06-24-2008, 12:48 PM
Soul TKR's Avatar
not sure about the block but the pistons on an LQ4 are dished... I'll try and search from some sort identifying marks...
Old 06-24-2008, 12:57 PM
Soul TKR's Avatar
check out this thread... it may help
https://ls1tech.com/forums/showthrea...light=lq4+info
Old 06-24-2008, 01:32 PM
jmm98LS1's Avatar
Thanks, doesn't look like the answer I need is in there though.
Just buying the block/crank, there's no rods/pistons to reference. Are there casting numbers on the block or crank that will tell what they are????
Old 06-24-2008, 02:12 PM
jmm98LS1's Avatar
I think I found what I needed.......in case someone else needs the info:
6.0 crankshaft casting number 12552215 = '99-'00 LONG crankshaft (non-ls1 compatible)
6.0 crankshaft casting number 12552216 = '01+ SHORT crankshaft (ls1 compatible)
Old 06-24-2010, 04:15 PM
Hi Volume's Avatar
sorry to bring it back from the graveyard, but where can the casting numbers be located on the cranks>? I found a Lq4 shortblock for sale, but the seller doesnt know the year make or model it came from and i want to make sure its NOT the older iron headed 6.0
Old 06-24-2010, 04:29 PM
jmm98LS1's Avatar
It's cast into the bottom of one of the crank throws, I can't remember which one. You'd have to pull the pan to find it. Easiest way to identify it otherwise is look at the rear main seal. If the crank sticks out about 1/2" further than the seal, it's the thicker rear flange. The thinner rear flange will be pretty close to flush with the rear seal.
Old 06-24-2010, 10:06 PM
89 formula350's Avatar
here is a link from another site
Old 06-26-2014, 12:16 PM
Grunkybouy's Avatar
Does anyone know what the journal sizes are on a 6.0 crank and or the 5.3 crank are? Are the cranks interchangable?
Old 06-27-2014, 04:05 AM
Quick Ranger's Avatar
The cranks are interchangable. The only thing, if you use a 5.3 crank in a 6.0 block, when you balance the assembly, chances are the crank will need weight added to it, since the pistons are heavier than 5.3 pistons. Adding weight will cost more at the machine shop.
Quick Reply: lq4/lq9 6.0 crankshaft/block identification (need help quick please!)
