Direct Port braided lines?
I have the TNT Direct Port system but I would like to replace the hard line for some braided lines because I heard that the hard lines leak. Where can I find the braided lines?
We have been using braided hoses for years. Hardline will not leak if you have a good flare. Keep in mind with the TNT distribution blocks if you do away with the hardline you are doing away with the support that holds them in place. Unless you build some type of bracket they are going to bounce around.
We custom make hoses to any lenght. Just give us a call if we can help.
Here is a link to some of the directports we have done that may give you some ideas.
http://www.nitrousoutlet.com/installs/index.asp
Dave
Dave
