Back fire issues
Old 06-24-2008, 03:53 PM
srpwr's Avatar
Default Back fire issues
I have a 95 nissan 240sx with a 02 LS1 w/ t56. My issue is... say Im sitting at a lred light and it turns green to go. My car will take of and drive fine but will back fire (Very Loud) a couple of times. What would cause this? Every thing is stock except the exhaust. That is Hinson long tubes into dynomax cats into magaflow mufflers. Thanks!
Old 06-24-2008, 04:14 PM
SMAX's Avatar
Is it backfiring through the intake or popping through the exhaust?
Old 06-24-2008, 05:10 PM
srpwr's Avatar
Its popping through the exhaust. (LOUD) I mean this is not like a little pop its more of a huge BANG!!!
Old 06-24-2008, 05:48 PM
98blackSS's Avatar
Inspect all plugs, wires and coil packs.. Has it done this since the swap or just started recently?
Old 06-24-2008, 08:29 PM
srpwr's Avatar
Its done it ever since I had the exhaust put on it...so basicly it has always do it. Some guy told me tha it could be because I dont have an X pipe.
Old 06-25-2008, 05:42 PM
Pop N Wood's Avatar
an air leak in the exhaust will do that
You might be running a little rich too.
In fact, an air leak near the O2's will cause it to run rich trying to compensate.
Old 06-25-2008, 06:31 PM
98blackSS's Avatar
As said above, check for air leaks too. Also make sure that a plug wasn't smacked/damaged during exhaust install. And as stated, an overly rich condition can foul plugs which will cause the backfiring too. A wideband scanner is a huge help here.. Should also be able to get a scan log and check how far it's trimming fuel too..
Old 06-25-2008, 09:32 PM
srpwr's Avatar
Thanks guys. Im going to take it to TSP tomorrow to see what thier scan tool says. ill let yall know.
