someone please help T-5 clutch line and fitting problem I NEED HELP
Old 06-24-2008, 10:09 PM
Joecrunk101's Avatar
Default someone please help T-5 clutch line and fitting problem I NEED HELP
i bought a t5 from some kid that had it in a camaro
he cut the line that goes from the master to the slave ...
i cannot find the fittings that go into the line slave and master and i cannot find the hose that connects the two..... dealer knows nothing parts stores know nothing someone please help .........
they are a weird non threaded fitting that is held by a roll pin ,,,,,,
i broke one pulling it out and the line is shot ...
Old 06-25-2008, 12:05 AM
wrencher
wrencher's Avatar
There has to be someone who makes a replacement line for your application?
If your looking to make a line goodridge is a company that makes/sells about every fitting known to man.
Old 06-25-2008, 12:24 AM
89txiroc's Avatar
I Might have Just the line for you. It is from a 89 Iroc which I just went from t5 to t56, Ill post a pic in a little bit for you to confirm the line.
Quick Reply: someone please help T-5 clutch line and fitting problem I NEED HELP
