need help deciding on new rearend!!!
Old 06-25-2008, 06:05 PM
Firehawk666's Avatar
Default need help deciding on new rearend!!!
ever since i bought my car a couple months ago, ive had a major grinding/dragging noise coming from the rear. after putting the car on the lift, we found that the pumpkin itself was untouchable bc it was so hot, yet there was plenty of fluid in it, and the fluid looked fine. there was also alot of play moving both wheels clockwise/counterclockwise (prolly about an inch worth) inside the rear. the thing is tho, the car drives fine, and doesnt make any clunks when pulling out or stopping or anything like that. im under the impression that i need a new rear (which i was planning on doing anyways) and was considering the 9 inch limited slip from moser. i still want my traction control (for now) but want something beefy enough for future upgrades. im not sure (nor do i know how to tell) which splines i have/need, and wanted to know if i can still use the factory driveshaft for now. help please???
Old 06-25-2008, 08:34 PM
subhumanzz's Avatar
moser 9", 4-channel, trutrac, 31 spline axles ( highest spline you can go with a trutrac)
Old 06-25-2008, 09:56 PM
jmm98LS1's Avatar
You can still use your factory driveshaft.
Old 06-25-2008, 10:05 PM
awesome...that settles that then. thanks guys. hey subhuman, i see you're from the Alexandria area...you know of any tracks or events around here worth looking in to?
Old 06-26-2008, 06:58 PM
EPP
EPP's Avatar
Moser 9 inch, starting at $2,400.00 shipped to your door. Bob
