need opinions for cam
mods are in sig i like to use the juice so i need a cam that will take the juice but i would like a good power making cam but i will putting close to 30 miles on the car everyday so i need an everyday driver cam that actually makes power also do not have a stall yet but planning on getting one between 2500 and 3000 thoughts and opinions would be helpful thanks all
Re: need opions for cam
get a stall 1st, u'll be surprised at how much it wakes up the car... with the 3.73's, get 1 with about a 2.0 str, maybe around 3200 or so... for a cam, if u want stock like, try the LS6 cam, or maybe the comp 212/218-.558/.563-115... anything bigger will need tuning with the A4... nice car for an 18yo by the way... also, maybe u can try to find some periods to make sentences, it makes it alot easier to read and understand...
Ditto get a converter first, Just make sure you get the right one for your future mods to.My choice for the money would be either midwest or tcs or tci, I wouldnt buy anything less than a 3500 myself.
With 3.73s and a 'verter, you'll never hook at the track without DOT slicks. If you still had 3.23s, I'd get the Yank SS3600. I personally wouldnt get a cam any smaller than a 216/216 on XE lobes. No sense getting those old comp grinds when new ones idle better and make more power. Don't make the mistake I did and have to change cams 3 times
hey thanks guys but tires aint a problem but my parents bought me the car i had a 68 chevy truck showed out. but started cutting off on me but i do pay taxes insurance and all the stuff i do to it so im not totally spoiled didnt even ask for it dad just brought it home hes had a couple vettes. but definitely thanks for the suggestions and keep them coming.
also dont mean to sound stupid but im not sure what you mean about the 2.0 str sorry
str is basically how hard the converter hits... if u had 2.73's, u'd want a high one (2.5-3.0), if u put a 2.0 with 2.73's, it would be real loose, but since u have 3.73's, a high str will break the tires loose very easily, so u can go with a lower one to help with traction... y DID u change the gears, anyway?
ha that is definitely the cam i need. i think as long as i leave everything else factory on the drivetrain it would work fine haha j/k. to answer the other question i changed the gears cause i thought it would help out cause i though i had a 3:23 turns out i got a 3:42 but i noticed with those gears it realy gets that speedometer moving so i think it woke the car up a little
no i thought the 6 speeds had 3:42 and the a4 had 3:23 that is why i changed and since i didnt find out til the rear was apart and already paying why not go ahead and swap them but i still have the 3:42 in a box
