true duals with a body mounted t/a?
Old 06-25-2008, 10:48 PM
chevyls1's Avatar
Location: where ever i can store my car. (palos hills,il for now)
Default true duals with a body mounted t/a?
does anyone know if you can run a h pipe if you have a body mounted torque arm?
thanks
cliff
Old 06-26-2008, 07:31 AM
teke184's Avatar
well considering any Hpipe setup is gonna be a custom job to begin with.
i'm thinking it will TOTALLY depend on the routing of the pipes.
possible i'm sure
Old 06-26-2008, 11:47 AM
LS1Tech Sponsor
Indukted1's Avatar
thanks
cliff
yes it can be done!!!
Old 06-26-2008, 02:24 PM
Pharcyde50's Avatar
I just finished fabbing up a custom 3" x pipe to go with my umi body mounted torque arm. I put the x right through the center of the t/a brace. The problem with trying to fab up an H pipe setup is there is not enough room for 2 3" pipes to make it through the passage in the t/a mount.
Scott
