Hesitation Problem, Need help
Old 08-18-2003, 04:15 PM
RED01TAWS6's Avatar
Default Hesitation Problem, Need help
Here's the symptoms of the car's problem. While Driving around town it seems to Heistate under 2000rpms and doesn't have the same power as it should. After 2000rpms it seems to smooth out and ride fine. UNDER WOT it is smooth but there seems to be a loss of power.
So what's wrong? I need this help ASAP!
Thanks In Advance
Old 08-18-2003, 08:47 PM
WS6FirebirdTA00's Avatar
Default Re: Hesitation Problem, Need help
same here man ill post in a sec
Old 08-18-2003, 08:50 PM
alright i had the same deal. first of all what mods do you have done? second check your plugs and wires. i had a problem with one of my wires being loose and before that i had a bad plug. also had to do with my tune and my maf ends. i got some ported ends and got predator to change my tune and it was nice. so post up or pm me what you have done and if its something like what i have i think i can help cause mine doesnt do it anymore lol
Old 08-18-2003, 10:04 PM
RED01TAWS6's Avatar
Heads Cam and all the bolt ons. N/A. Going to replace plugs and wires. Lemme know what you found out.
Thanx
Old 08-18-2003, 10:13 PM
well i had to have my tuning adjusted because my fuel trims were too far off and it casued it to bog. putting ported maf ends helped out a lot too but most of it was because of my plugs and wires. hope this helps. do you have any custom tuning done?
Old 08-18-2003, 11:22 PM
RED01TAWS6's Avatar
Yea RMS tuning going back Saturday, but first I'll change my plugs and wires. How much did the plugs and wires help? A lot?
