Quick ?'s about LS1's and F/I
I'm in the middle of a discussion on another forum, and need some help. I've read somewhere that LS1's and a decent amount of boost just don't mix very well unless a lot is changed... Can anyone help me out a bit? I'm having a heck of a time, and if I'm wrong, then just tell me, but would turboing a stock block/internals ls1 past 10 or so psi cause problems because of the aluminum block? Thanks
Customizing Director
Nothing wrong with boosting a LS1 if its built right. Basically the stock bottom end (Rods/Pistons/Rings) is only good to 500-550rwhp. Anything past that and you'll need a forged bottom end (internals) to be safe. Things like trans and rear end will obviously need to be built with more power regardless of how that power is made.
Hmm...for some reason I was sure that the LS1's internal's hated F/I, which I was wrong...500hp isn't too shabby. Around how much psi would that take to be "too much". And yes, I realize that the rest of the drivetrain would need upgraded, I was mainly concerned with the motor.
I made 467, but had really bad valve float. Now thats fixed. Once rear end and gear is in i will go back for more boost and tunning.
Lsx love turbo's.
Chris
Sorry for not searching...but I went to the turbo FAQ, and looked over the page quickly, and thought I might get an answer easier by starting a new thread. I know what it's like having new guy coming in and wasting space, but I needed an answer, sorry for the trouble. And damn...I won't lie to you guys, IF I had the option, I'd go LS1 any day with the way that these beasts put down power.
Here is a link with alot of guys running boost and there experience with their mostly stock internals. Hope this helps...
https://ls1tech.com/forums/showthrea...=ls1+internals
Mine lasted long enough to destroy people on the streets for a few months and run a dozen or so low 10 second passes with an untouched bottom end. Of corse the end result was my sig pic but it was great while it lasted. It put down 680 rwhp at 14psi.
