Help, need 160degree T-Stat for Turbo Build!
The 160degree that I bought from Autozone didnt fit. I bought the one with the tstat housing/neck and the tstat was too wide for the block.
I did see a Mr Gasket Tstat and it seemed to fit in the stock tstat neck, but on the packaging it said for 2004 and Newer LS1s?
Where did you guys pick up your tstat from?
I made that same mistake. Got just the thermostat from jegs because it was cheaper. Ended up giving it to my buddy with his 04 GTO because it didn't fit my car . You need the thermostat and neck-Got mine from hypertech, no problems. Changed in ten minutes.
