Deciding On A H/C Setup
Restricted User
Well I was looking into the TSP H/C packages. I am most likely going to go with the Torquer 3 or MS4. I just don't know which heads I should pick. It's a toss up between the PRC stage 2.5 5.3 or the PRC stage 2.5 LS6 heads. Any and all input on this possible set up would be great. The car is an M6 w/ 4.10's. I am also curious between the MS4 or the Torquer 3 cam, and which will benefit me the most. Also I would like to know what kind of numbers (both dyno and 1/4) this setup or similar setups put down. My current numbers are in my sig. I am also running a FAST 92/92 setup up which will be used with the H/C. Any input would be great....thanks.
-Dave
-Dave
I don't think you can run the MS4 with milled heads. They have revised the LS6 heads. You should get those and have them suggest a good cam to go with.
https://ls1tech.com/forums/generation-iii-internal-engine/943838-prc-ls6-heads-get-face-lift-225cc-runners.html
Restricted User
https://ls1tech.com/forums/showthread.php?t=943838
