Door skin is seperating.....what glue?
Old 06-28-2008, 11:12 AM
Pewterpower's Avatar
Default Door skin is seperating.....what glue?
The leading edge of the door skin, from the trim up, has seperated. I can pull it apart enough to run a new bead of adhesive on it, but what should I use?
Can I use something from like a Walmart, or do I need something special from a body shop?
Old 06-28-2008, 01:18 PM
Ntimid8r7's Avatar
You should see if you can get something from the body shop. **** from Wally world will not work. I had the rear part of the door skin on a 94 Z come apart and that is what I had to do. I tried all the different epoxies and it didnt work.
Old 06-28-2008, 01:48 PM
I wonder if AZ or Pep Boys would have something like that.
Old 06-28-2008, 02:24 PM
bdyman's Avatar
panel bond, i suggest 3m or fusor panle bond, need the material and the gun
buy from the local body shop supplier
Old 06-28-2008, 03:04 PM
A quick google turned up some Fusor items at NAPA for about $20. Thanks.
Old 06-29-2008, 12:59 AM
02 WS6 864's Avatar
Let's see more detailed pics. When I picked mine up in 01, I thought I had a paint issue. Now my brother in law thinks the doorskin was ready to seperate from day one!
Old 09-28-2014, 10:02 PM
slowpoke96z28's Avatar
Bump...
Old 10-03-2014, 11:37 AM
ZForce1's Avatar
You need a fiberglass bonding adhesive. Eckler's corvette sells it. I had a similar problem when someone tried (unsuccessfully thank goodness) to break into my car. Pulled the door plies apart. Can't remember the name, still have some at home, I can look later.
Old 10-03-2014, 12:03 PM
scj
scj's Avatar
I had this issue with my 95 and couldn't get anything to hold up, it worked for a while, but vibrations of driving took it's tole and it kept separating. I honestly would either have a body shop pull the whole door skin and professionally put it back together or have the door replaced.
Old 10-04-2014, 08:26 AM
ZForce1's Avatar
It's Vette Panel Adhesive/Filler for SMC & fiberglass panels. Do a search for vette panel adhesive filler 870. It will work. Mine has held up for several years now. From the looks of it my doors were alot worse off than yours.
Old 10-04-2014, 08:27 AM
ZForce1's Avatar
Keep it clamped down real good during curing process. Might have to remove the door in your case.
Old 10-09-2014, 07:10 AM
silvertl's Avatar
3M makes some AWESOME adhesive bodyglue. Just like he states ^. Local body supply store and get the 2-part 3M glue. Works amazing and holds up very well.
Quick Reply: Door skin is seperating.....what glue?
