LS6 intake swap
Old 06-28-2008, 04:42 PM
RX7ls's Avatar
Question LS6 intake swap
I am swapping the 98 LS1 intake for a LS6 intake. The intake seems to fit just without any problems. I have seen on this and other forums that I should buy different coolant hoses and blocks for this conversion. Is it needed ? Why ? Thanks,
Old 06-28-2008, 05:17 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
You can buy the kit from a sponsor
You can grind the ribs off the bottom of the intake or you can flatten the LS1 coolant tube with a hammer
Old 06-28-2008, 05:21 PM
TransAmcoupe98's Avatar
I wouldn't suggest the throttle body bypass mod when swapping out intakes. By taking out the steam tubes, it can make the #7 cylinder run hotter...Just grind down the ribs on the bottom of the intake...
Old 06-28-2008, 06:15 PM
plaf713's Avatar
grind down the tabs, saves you 30-40 bucks and lets things run the way they are supposed to
Old 06-28-2008, 06:44 PM
LS1C5Vette's Avatar
TB Bypass? I think you mean dont block the coolant holes in the back of the heads (ie getting the ls6 coolant lines), I agree just grind the tabs off the bottom of the LS6 and slap it on, its what I did.
Old 06-29-2008, 01:36 AM
biga0206's Avatar
https://ls1tech.com/forums/showthrea...ght=intake+ls6
This helped me out and it shouds what you need to do.
