SDCE w/ Stock Damper Question
I have the stock damper with sdce set up.....(I know I should just get a ati damper but don't have the money now)...
I used red locktight on the 3 bolts that hold the pulley to the hub and it works fine for a few hours......have not even built boost.......after a few hours the supercharger crank pulley gets a slight wobble....
then I retightened the 3 bolts and the wobble goes away for a short time
I am going to pull hub/pulley off and make sure the 3 bolts are all in contact with the stock balancer...but I was thinking of tightening the 3 bolts down and putting a few welds to hold the pulley to the hub
any other ideas
any other ideas
any other ideas
any other ideas
Im not too fond of this SDCE setup, drilling a balancer like such is not the proper way of doing so.
The SDCE pulley I had for the stock balancer didnt have any bolts or need any drilling. It was similar to the procharger 6 rib pulley with pins. I ran mine for a couple years with the stock balancer and never had an issue, not sure if they changed something and made it different.
Either way before something gets damaged I would call SDCE.
I have only come accross 1 setup as such, and it had 3 x 3/8s bolts about 2in long that threaded into the balancer. It was a pulley that was the same dia as the balancer but it offset the ATI bracket another .150.
I remember they changed the crank pulley to a 2 piece design that could either be used with a stock or ATI damper. I have never seen one though. The SDCE crank pulley I have for the stock damper looks just like a regular procharger LS crank pulley except its 7.25 diameter and is 8 rib. The one on the car now is just like the procharger 8 rib and bolts to an ATI damper.
I'm curious to see some pics of it since I never have seen the 'new' crank pulley that can be used with either balancer..
I will post up pics tonight....working on it now......I called sdce last week and was told to remove pulley and make sure the 3 bolts were hitting the balancer at the same time...I will check it....but don't think thats the problem
Do you still have the one piece sdce crank pulley that you might be willing to sell?
Working on cleaning the parts up......I powder coated them and am going to re-do it after I figure this out.........
Pic of hat:
But I believe the red locktight was not where the threads engage......
Also, can someone tell me when you install the pulley....the 3 screws hit the damper.....but which way do you want to turn it before you tighten crank bolt
Will post pic of pulley, but it is just like the one that bolts to superdamper.......you just drill out the holes needed in pulley
Pic of hat:
better video
Look alright?
Originally Posted by kp
You are going to get some runout with the stock damper, mine wobbled a little but never threw a belt. As long as bolts arent falling out or loosening up and its not really bad give it a try. Just be careful because a pulley coming off the front at higher rpm can do some damage under the hood.
i know this is old , but i bought an sdce kit to use with the stock balancer and sent sdce pics and waiting on what else i need for tools , but this is whats throwing me off from your pm you sent me , no hole in the billet metal piece .
