Corvette Performance - charging system fault
View Full Version : charging system fault
Red2001C-5
06-29-2008, 10:54 AM
The voltage had started dropping off and i started to get the system fault once in awhile. i have changed the alt and battery and now i am getting the massage all the time. is there something else that i need to check?
petercln
06-29-2008, 04:17 PM
There is a lot of information about this subject over on the corvetteforum.com.
I had the same warning on my c5 z06 and it ended up being loose and dirty wires at the starter comming from the battery.
You may want to check and clean all the grounds. Good luck
Red2001C-5
06-29-2008, 04:57 PM
thanks for the info, ill check out the other web sight.
TLewis4095
07-11-2008, 02:44 PM
Here is the only real long-term fix....the OEM units breakdown w/heat & the low voltage fluctuations will trigger the code.
http://i262.photobucket.com/albums/ii115/RevXtreme1/HighheatAlt001.jpg
http://i262.photobucket.com/albums/ii115/RevXtreme1/HighheatAlt002.jpg
These also come with our latest billet piece....an overdrive pulley to match the rest of our pulley's.:thumb:
$489 introductry price.
Here is a pic of the dash after 1 hr idle heat-soak:
http://i262.photobucket.com/albums/ii115/RevXtreme1/HighheatAlt.jpg
