what does degree in a cam mean?
Old 08-19-2003, 02:12 PM
pdd
pdd's Avatar
Default what does degree in a cam mean?
and do i have to do it on the tr224? does it come degree'ed? i have a c5 vette wit a 6sp
Old 08-19-2003, 02:42 PM
99C5JA's Avatar
Default Re: what does degree in a cam mean?
Degreeing the cam checks to make sure that cam was ground properly. It never hurts, but I don't think its really necessary for you to do so (I didn't).
Old 08-19-2003, 03:14 PM
1999_SS_M6's Avatar
As stated above, it is to ensure that the grind is correct. However, you're not just dealing with the possibility of someone making a mistake when cutting the cam, but also packaging, shipping etc etc.
Basically, you install the cam and use a degree wheel and dial indicator (yes you need some other equipment too) to bring the cam to it's advertised lift, and compare to see if you are at the actual valve timing that your cam card advertises. If not, you will need to advance or retard the cam to achieve that valve timing. Otherwise, your torque/hp peaks will move around on you, and piston to valve clearance could be affected.
Old 08-19-2003, 11:15 PM
Freak's Avatar
remember its not always the cam thats off, the timign set can cause the timing to be off too.
Old 08-19-2003, 11:42 PM
99 Black Bird T/A's Avatar
Received 1,431 Likes on 991 Posts
As 1999 said for example...
Cam doctor is used to determine specs of how the cam is actually ground to confirm it's what it's supposed to be. This is when you find out that 224 XE-R w/.581 lift 114 LSA cam with 4 degrees of advance is really a 113.2 LSA cam and was ground sligthly retarded and only has 3.1 degrees of advance, and is 224.3 degrees of duration @50 with .580 lift. This data can effect how you want to set up the cam when you degree it in.
The above XE-R installed dot to dot would probably end up with 3 degress of advance, by degreeing you'd know it was ground due to manufacturing variance with a little retard so by degreeing you could adjust for it being 1 degree off and get your full 4 degrees of advance.
Quick Reply: what does degree in a cam mean?
