Killer 4th of July Deals Part 1
Old 06-30-2008, 09:58 AM
Nitro Dave's Nitrous Outlet's Avatar
Default Killer 4th of July Deals Part 1
Celebrate 4th of July with Nitrous Outlet. To celebrate the 4th of July we are offering some great discounts to save you money. So go ahead and spend a few extra dollars at the fireworks stand!
Nitrous Outlet plate conversions
Nitrous Outlet plate conversions give you the opportunity to upgrade to the best nitrous plate design on the market with out buying a complete system. So weather you are just looking to clean up your install or just looking for something better than what you already have this may be for you.
Our nitrous plates are simple the most efficient high flowing plate on the market.
A few reasons why..
* Plate is only ¾ inch thick.
* Inlet fittings are aimed at firewall for the best look and fitment available.
* Easy to install throttle extension bracket.
* O-ringed gasket machined into plate for perfect air tight seal.
* 6 fuel and 6 nitrous discharges for the best atomized flow.
* Flows up to 400HP!
78mm Plate conversion=234.00
85mm plate conversion=234.00
90mm plate conversion=234.00
92mm plate conversion=252.00
100mm plate conversion=252.00
52mm LT1 plate conversion=256.50
58mm LT1 Plate conversion=256.50
Mono Blade LT1 Plate conversion=256.50
78mm Plate conversion dual stage=297.00
90mm Plate conversion dual stage=297.00
92mm Plate conversion dual stage=297.00
Brand X Nitrous System
Brand X Nitrous Systems are designed for the budget enthusiast looking for a great deal with out sacrificing quality. With the Brand X Nitrous systems everything was custom built and designed to meet the high expectations that Nitro Dave’s requires in order to be stamped with the Nitro Dave name. No need to settle for anything less than Brand X Nitrous.
A few reasons why.
* Black powder coated bottle with high flow bottle valve.
* Small base solenoids that pack a big punch. Flow 200 HP! Opens under
pressure and heat.
* 1/16 nitrous nozzle flows 200 HP!
* Includes jetting for 50-100-150 HP
* 16ft -4 main feed line.
* Stainless steel quick release bottle brackets.
Brand X Single Nozzle Wet System only 299.00
Need Both?
Hurry deal ends soon!
Call in your order toll free at 1-866-648-7637 or 254-420-3630
Happy 4th!
Dave
Old 07-01-2008, 11:28 AM
Still kicking
Old 07-01-2008, 02:08 PM
krazy4's Avatar
$299.99 is an awesome price for that kit. Too bad I just bought a kit
Old 07-01-2008, 03:30 PM
joe0121's Avatar
that is a smoking deal, where do you route the nitrous cable for a c5 corvette coupe always thought that would be the difficult part of the install.
Old 07-01-2008, 03:39 PM
sidewayz28's Avatar
carry Nitrous Express bottles?
Old 07-01-2008, 06:26 PM
Yes sir..
Old 07-02-2008, 11:13 PM
Dont miss out ...
Old 07-03-2008, 06:46 AM
JoeyGC5's Avatar
So does the Brand X kit come with the lines from the solenoids to the Nozzle also? No lines other than feed shown in the pic.
Old 07-03-2008, 10:52 AM
LOL,
Good call. yes sir it is complete. Looks like we left it out of the picture...
Dave
Old 07-04-2008, 10:32 AM
Tzion_ben_Arthur's Avatar
So, Brand X + plate system and still get free bottle heater before the 7th????
$299.99 + $234.00 + free heater = to good to be true! If so,I will buy this weekend and I was not even going to use the stuff.
Art
Old 07-04-2008, 10:53 AM
3fingas's Avatar
How bout a dual stage 4150 plate?
Old 07-07-2008, 07:30 PM
Art
Art,
Sorry the Free heater deal is another special all together. It is also only good for purchase of a Nitrous OUtlet brand system.
Sounds like you need the NX gemini quad...
Old 07-09-2008, 03:28 PM
We have extended this special until the end of the month
Old 07-09-2008, 05:08 PM
MnMFTW's Avatar
If you had paired this with the free bottle heater, you would have a customer.
Old 07-09-2008, 05:22 PM
I would be out of buisness
Old 07-10-2008, 12:22 AM
MnMFTW's Avatar
Really??? I am not a business major but I am not to sure how that works.
Anyways, I re-read the comment, and it seemed a little negative, I didn't mean it that way, I just thought thats what the two deals could be used as, but it turns out they can't. I would definitely have been all over that, and accessories soon after.
As I am sure many people would.
Old 07-10-2008, 10:08 AM
Chris@NitroDaves
Guest
Posts: n/a
the sale will be extended till the end of the month.
-Chris
Old 07-15-2008, 09:12 PM
Cant beat this deal..
