ArKay99
06-30-2008, 06:47 PM
Is there a reason to re-gap a plug in an LS1-LS2, LS6, etc motor?
I've been doing some research on this, but I haven't found what appears to be a 'definitive answer'. I'm wondering if there is an 'ideal' gap for a plug. For instance the stock plain vanilla delco plugs are pre-gapped at .060" if I am not mistaken. I am currently running NGK TR6 IR's that were gapped at .030" from the box.
I'm running what's in my sig and have re-gapped my plugs to .045" because someone who seemed to know more about it than me, (I don't know anything about it), told me so. I read somewhere that you should run the largest gap you can without 'blowout'. It was a while ago and I forgot about it until today because I was dynoing my 'new' LPE 403. The car made great numbers for what I was expecting. I know it's probably more of a tweak thing, but I'm wondering if there is an 'optimum' gap for a plug in a certain size motor, or for what compression ratio, or the kind of power you make, or for any combo of the above, or for no combo.
Will the flame grow quicker from a longer spark causing a faster burn? Is gap length more of a factor with carbed motors vs fuel injection?
