Help meeting fuel needs
I have a 00 SS with a 67mm turbo, looking to get around 600hp. Right now I have aeromotive rails, 60lb injectors, and a racetronix 255 kit not installed yet. I was planning to run the single racetronix with a -8 feed and stock feed as the return.
Will this surpass my needs for fuel?
If I install another Walbro pump intank with the racetronix, will I still need to run the -8 line?
Or should I do the dual pumps and the -8 feed?
Would it be a waste of money to run the racetronix kit with another Walbro, as opposed to running 2 walbro pumps?
Hope that makes some sense
Thanks
Thanks
A single Racetronixs pump kit will not work with a second Walbro pump you will want to do it right the first time. -6 feed and return will be enough for your powr goal but one pump will not. Give me a call I can help you with your system needs.
Nate
Nate
