Polishing
Old 08-19-2003, 06:23 PM
SSpilot's Avatar
Default Polishing
What is the best tool to buy to polish to a chrome finish. I'm thinking some type of a dremel, but if anyone can be a little more specific and tell me what else I need to buy it would be great, thanks.
Old 08-19-2003, 06:26 PM
LS1Tech Co-Founder
Nine Ball's Avatar
Default Re: Polishing
Dremel would take forever. Depends on how large the object(s) you are polishing are. Take a look at the Eastwood link on the right (the yellow one) and check out their polishing stuff.
Most polishers use several different tools for the job. Depends on how rough things start, the space they have to work, and how quickly they want to finish.
Tony
Old 08-19-2003, 06:38 PM
theblur98ss's Avatar
Eastwood had everything you will need. I've tried to polish with soso results. I was using an old furnace blower motor that I had turned into a grinder. The RPM's weren't high enough and I didn't get the luster I wanted. I would only use a dremel in tight areas or on small pieces.
Old 08-20-2003, 06:12 PM
SSpilot's Avatar
I checked out Eastwood, and they had a "Mini Die Grinder" that was reasonable priced but rather small. the other two were either $130 or $260 and I am pretty sure they have to be bolted down to use. I have never really polished anything before, but what I wanted to do was just get little grinder for $27 but it pneumatically powered and I was just hoping to plug something into an extension cord. Help please, really want to get started. Here is the Eastwood site: http://www.eastwoodco.com/email/defa...geName=default
thanks
Old 08-22-2003, 05:14 PM
SSpilot's Avatar
ttt...please help
Old 08-24-2003, 04:39 PM
SSpilot's Avatar
anyone
Old 08-24-2003, 09:53 PM
do a search for todd2001ss(i think is his name here) in his sig there is a link to his polishing site. It should have all the info you're looking for
Old 08-24-2003, 09:57 PM
98TAauto's Avatar
i'd just use a dremel for engine bay stuff. Even if it takes a while, its worth the time!
