Just ordered headers??????
So i just ordered my headers through speed inc. I was going to get 1 3/4 but he told me that i should just get the 1 7/8 so i listened to himsince im sure he knows a little more than i do. What do you guys think i should have gotten? Also what do i have to get with it to install it all? Such as gaskets o2 sims or any of that stuff and what brand of gaskets and stuff. Thanx
Stock gaskets. Stock header bolts. No one sells O2 sims anymore... either wait til you get tune or just ignore the light.
Also I recommend getting o2 sensor extensions...you can manually extend the wires...but it's just much easier to buy the extensions..takes 2 seconds to plug them in..good to go.
1 Post
1-7/8" are for big cube motors, and stock 346 aint really big enough for that.
I would get the rear o2's turned off by a tuner instead of spending the money on simulators. then you could get the egr and air turned off too ( if you have egr ) money better spent there.
Stock header bolts are fine.. I reused my stockers and all kinds of people reuse them. I think they are only supposed to be torqued to 12 ft/lbs so its not like they are handling a hiuge amount of torque. If anyone is stretching their header bolts they are tightening they wayyyyyy too much.
Also after you get the headers in and drive the car a bit recheck he headers bolts a couple times. they tend to loosen up a bit the first few times they are heated and cooled.
I cant wait to get them here. They are gna be loud. I got the headers with off road y and its all going through slp loud mouth Do you guys really thik ill loose power since im getting 1 7/8 headers instead of 1 3/4? Should i call them back and see if i can switch it back to the 1 3/4
Ok i just wanted to make sure cause i mean almost $1100 is a lot of damn money to spend and loose power lol. Thanx for all the help. Is it true that i have to lower the k member to install these? Thats what a friend told me and i wasnt sure
That is a lot of money! Good thing I only spent ~$520 on my entire setup For $1100..your car had better run faster than mine! Time in my signature.
No you won't have to drop the K.
I have Kooks 1 7/8" Headers on my car and there is no drooping the K member involved. You will have to the car as high as you can though to tilt the header upright enough to slide the drivers side in. Also may have to undo the motor mounts to move or tilt the engine up into place. I hope you are replacing the stock motor mounts to Poly mounts? you will also will have to undo the steering shaft.
No you won't loose any power overall with 1 7/8" headers but the Power curve will be more towards the higher RPM range so there will be a little less low end torque (3000 rpm and below) which you may notice but it wont be anything drastic.
