Moser 12 Bolt Streetability
I am buying a used 12 bolt. Here is the skinny on the rear:
Moser 12 Bolt, 3.73 gear, Eaton True Trac differential, 4-channel ABS, 33-spline axles
I know I am getting a good deal on it. I just want to know how streetable this set up will be. Thanks.
Very streetable. I have a similar setup, but with 4.10 gears and 31 spline axles. It's heavier, so your handling will suffer (unsprung weight increase), but other than that, it's fine.
-Mike
-Mike
