Need M6 Part..
GM no longer carries them or even sells them, what I did when I had that console I used a thin piece of Aluminum and contoured it around to fit and even found out it works better that the cheap plastic bezal that came with the console.
It's going to be hard to find if you do want the factory piece though.
I might try a different way to get one..
I got ahold of the Leather(whatever it is) Shifter Boot that goes in the Interior..when I get the chance I'm goin to the Junk Yard and getting another A4 Console Piece. I'm going to take that one apart and cut it all out in the Center to where it will measure up to the M6 piece. Then I will attach the Boot to that and put a piece of Aluminum in the open spot. I'll put the M6 Shift Pattern Decal on that if I can find one.
