dbw not working
dbw not working
Anybody have any ideas why the dbw set up is not working on our 87 monte with a 2003 6.0. The pcm is dbw we have the pedal assembly and the dbw module. car will start and idle. but no throttle movement. just looking for troubleshooting ideas.
9 Second Club/LS1TECH Sponsor
Whenever there is no throttle movement, codes are set. You need to read the codes to get an idea of where the problem is.
It could be wrong/bad pedal, wrong/bad TAC module, wrong pedal-to-module harness, bad throttle body, broken wire, etc.
Are all the parts from the same vehicle?
I've seen people piece these systems together from Ebay to save money, and spend months trying to figure out they had the wrong combination of parts.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
So if the engine stalls out and dies causing a code it will disable the throttle?
