Road Racing - would a uD pulley help with PS boiling over?
STRIPSTAR
07-01-2008, 12:40 PM
Seems to get overspun to me. It has a big ass pulley on it as it is.
subtlez28
07-01-2008, 07:57 PM
Wondered the same thing myself.
I wonder if it would impact effort at idle (while parking).
When I looked into it B4 every one said to put in red-line fluid.
Or get an aftermarket pump, but I don't have that link handy.
LSGunZ28
07-02-2008, 03:11 AM
My power steering isnt good at low RPMs and I have a 25%udp
stock it felt better
Feffman
07-02-2008, 06:02 AM
The CTS-V power steering cooler is VERY small for the job at hand and has a boiling problem. Most guys are simply flushing the stock fluid for new Red Line power steering fluid before a track day or installing a larger cooler.
Feff
Matt87GTA
07-03-2008, 11:53 AM
I have a March UD pulley on my 99 TA and a small tube and fin cooler (one U bend tube, about 12"x4"x1") and I don't have any issues at all with overheating the PS fluid anymore. I also flushed the system and filled it with Valvoline synthetic fluid (cheap, readily and easily available for me) when I put the cooler on it. I hung the cooler behind the radiator on the left side using some zip ties and wire loom to protect it from rubbing through.
I also had a 96 Z28 and had the same "mods" done to that for the PS system and never had a problem with it boiling over once they were in place.
I guess it might require a little bit more effort at idle in parking lot type manuevers, but with an M6, you are always giving it a little bit of throttle to get going while releasing the clutch anyways so it isn't a problem.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
