F... installed new altenator and it didn't fix my problem!
Damn it to hell... Been havin this low voltage problem for a little while now. The car reads normal voltage but once it warms up it pretty much is running off the battery and hovers in the 12.0-13.0 volt range. Drive it even longer and it'll dip into the 11's. Figured it'd be the altenator right? Wrong
Changed the altenator tonight and its doin the same thing. Assuming the voltage regulator is built into the new altenator, I'm guessing this is not the problem. What gives?
Yeah I'm gonna do that after work. measure it under load I presume? I doubt it's the altenator anyways, the thing is new and maybe has 1 minute of ideling on it
I had the same problem a few months ago. I replaced the original, and the replacement was bad. Had to do it twice before I got one that would work. Both of them were AC Delco. So it's possible you did get a bad one.
rebuilt are actelly better , they are rebilt in usa and new are from where? china or taiwan think aboutt that
and i tried 3 different brrands from delco autto zone and this place by my shop
i blew ouot 6 of them in 2 weeks.
the problem? nott enough amps
auutozone amps for our car 00 5.7-102 amps ****
delco is like 135 i think
i ordered my 200 amp alterrnator today for like 299
this shouold do it and checck everything after i went WOT they blow
Altenator is a remanufactured 102amp factory replacement. But like I said, the old altenator was said to be just fine. Big 3 upgrade is probably my next option in case I have resistance in the ground connections and/or altenator power wire. Is it necessary to upgrade to 0awg on the altenator? I have stinger 4awg layin around here
Big 3 is chaging your battery/alternator/grounds wires to bigger wire, I recent did this with a 200a alt and I run steady at 14+ volts. There is a kit available pm for info as they are a non sponser.
A local guy had a similar problem, and it ended up being a bad connection inside the plug that goes into the alternator. He found it by wiggling the pigtail, it wouldn't charge well at all if he didn't touch it, but as soon as he lifted up on it, it went to full voltage. Might not be your problem, but it's free and worth a shot.
brian does your battery light work?? it uses the the 194 bulb as a fuse oddly enough and the resistance on that bulb is what actually excites the alternator if im not mistaken, there is one only one wire on the alt plug if im not mistaken, but there are 4 pins on the connector one requires the bulb and one is a self protected one so you wont blow the alt. depends on what vehicle is how gm did that i think. anyway doesnt sound like a bad alt sounds like its loosing its signal that tells it to charge.
i know most of this becasue of the v6 swap i did and the pan in the *** i had trying to get mine to charge i ended up wiring it to switched ignition through the protected circuit on the alt. i might give that a shot
