lq4 power loss
Old 07-02-2008, 07:53 AM
99hugcam's Avatar
Default lq4 power loss
Im on a really tight budget first off. If I was to run an lq4, a trex cam, and stock 853's, how much power would I be sacrificing because of the compression? How cheap could I find some lq9 pistons and would they work w/ the lq4 rods? Thanks
Old 07-02-2008, 08:49 AM
thunderstruck's Avatar
ive read that 1 point in compression is worth 2%, so at this power level you really arent losing much
Old 07-02-2008, 09:02 AM
s346k's Avatar
the cubes will make up for the loss in compression. i would expect the t-rex to be a little better suited to a 6.0, as it sits in the 346 you need like 7k+ rpm shiftpoints to utilize its powerband.
Old 07-02-2008, 04:14 PM
99hugcam's Avatar
so you think that would be a descent budget combo- lq4, trex, and stock 853's? Which head gaskets should I use and what compression should I yield? What kind of whp do you think w/ ls6, ud pulley, 4.10's and bolt ons?
I want to do this so when I do have the money Ill have the block to make a 408 and can run some ported l92s and vic jr intake! But right now Im broke. Thanks
Also, what years has the short crank so it will work w/ my manual?
Old 07-02-2008, 04:29 PM
99hugcam's Avatar
ok, just asked him and the engine came out of an 04. Is this the short crank that I need? Thanks
Old 07-02-2008, 04:50 PM
jmm98LS1's Avatar
yep, that crank will work.... '01+ is the shorter style.
Old 07-02-2008, 09:20 PM
99hugcam's Avatar
thanks, thats what i wanted to hear! Any suggestions on head gaskets? Should I go thinner to try and get some compression back? Thanks
Old 07-02-2008, 09:30 PM
ineedatruck's Avatar
i wanted to do this with my motor swap but shop is saying the accessorie placement on truck motor wouldnt look good
Old 07-02-2008, 10:29 PM
99hugcam's Avatar
what does that mean? I thought you only had to change the crank pully so the belts would line up?
What exactly do I need to make this swap work? Any Harness adaptors, etc? Thanks for all the help guys!
Old 07-02-2008, 11:48 PM
Soul TKR's Avatar
mill your heads and up your compression
check out my sig...
Old 07-03-2008, 02:23 AM
99hugcam's Avatar
how much to mill and will there be ptv issues? Thanks
Old 07-03-2008, 12:40 PM
99hugcam's Avatar
anyone
Old 07-03-2008, 01:43 PM
ss.slp.ls1's Avatar
Originally Posted by 99hugcam
anyone
Have you looked into bolting on stock 5.3 heads rather than the 853's? IIRC the 5.3's will flow more. Don't quote me, but I think you could get away milling the heads .15", the stock LQ4 pistons are dished, so I don't think you will have any ptv clearance issues. But you should be checking all your clearances anyway right?
Old 07-03-2008, 01:53 PM
Soul TKR's Avatar
and what cam are you using?
Old 07-04-2008, 12:04 AM
99hugcam's Avatar
Trex cam. And soul tkr how did you get 364 c.i.? I thought it was 370? I already have the 853's so ill prob run those, besides I thought you had to use a bigger exhaust valve w/ 5.3's? So if I run 853's milled .15 which gaskets should I go w/ and what cr would that put me at? Thanks
Old 07-04-2008, 12:16 AM
ponyhater27's Avatar
LQ4 is 364 and LQ9 is 370 I think. Anywho I have pretty much the same setup that you are talking about building. When I got my valve job my heads where milled a little but I have a LQ4 bottom end with Trex and 853's, LS6 intake, and bolts ons. I'm getting my car dyno'd Sunday I will let you know what kind of power I made. Shooting for 450 but I'm afraid the heads are going to drag me down. Oh and you won't have to use any other wiring harness for the LQ4 all you will need to do is put the 5.7 crank pulley on it.
Old 07-04-2008, 12:23 AM
99hugcam's Avatar
Great info. I will be using the march pulley that was on my ls1. How much where your heads milled and what gasket/ thickness did you use? Thanks and keep me posted on how it turns out.
Old 07-04-2008, 12:24 AM
ss.slp.ls1's Avatar
You can use 5.3's no problem. The stock CR of the LQ4 is 9.41:1. With milled heads (and possibly running a cometic gasket) I would shoot for a CR of ~11:1 for a NA build on pump gas.
Old 07-04-2008, 08:43 AM
99hugcam's Avatar
I wont be running 5.3's though. would all of that be about the same if I milled 853's .015" and ran .040" cometics? Thanks
Old 07-04-2008, 08:53 AM
AINT SKEERED's Avatar
My 241's are milled .022 and with my lq4 i am around 10.4 /1 . I am running an f14 cam and sounds tamer then my f13 with the stock cubes.
Runs very strong though. Have not dynoed yet but it pulls harder then my 346 that made 441rwhp/410 tq.
lq4 and lq9's are 364 c.i. to get 370 c.i you bore the block .030 over.
