Anti-Surge system?????
Hey Guys, Finishing up my P600B twin intercooled procharger install on a 97 LT1
and I have
2 booklets for directions. I was looking over them and I see that one booklet
tells me to hook up an "anti surge" from the proflow to vacuum port on the
drivers side of intake manifold.. Is that the BOV?? And do I need to do this.
The other booklet tells me nothing about it and its for the same system.
and I have
and I have
and I have
not necessarily. if you go to exoticperformanceplus.com and look up the installation instructions for the procharger system, there is a section that deals with the hook up of an anti-surge valve. it takes higher pressure air from after the blower and redirects it back infront of the blower. im a newbie myself to the FI stuff, but they list an anti-surge valve and a BOV as two different parts....the stock procharger kit does not have a BOV, but it does have the AS valve. the procharger race kit i bought has a BOV and no AS valve. both valves have a similar function but there is a difference.
maybe bob from epp can chime in and shed some light
Blow off valve can be used for either super or turbo
the purpose for both applications is when the throttle body closes it won't "surge" or stall the compressor. their purpose is the same.................
no difference. what your talking about if its redirected or vented to atmosphere.
