qa1's
Old 07-02-2008, 12:32 PM
89Formulaws6's Avatar
Default qa1's
i got some from my roller it has one **** on it which was do i adjust it for the track?
Old 07-02-2008, 12:48 PM
99ssleeper's Avatar
english please.
im assuming you mean which way...well..are these fronts or rears? SA or DA?
Old 07-02-2008, 12:50 PM
sorry i dont know much about these
they are the front coil overs and have only one adjustible ****
whats sa or da?
Old 07-02-2008, 01:10 PM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Hello, sa is single adjustable, da is double adjustable. You have the single adjustable shocks. Turning the **** clockwise will stiffen up the shocks,counter clockwise softens them up. You will need to test it at the track because each car is different. Try 1-2 clicks clockwise (harder) for a starting point. You will need to adjust it to what works best for your car. If you have any questions please give us a call. Our tech/sales dept is open Mon-Fri 8:30AM-6:00PM. We will be closed this friday for the holiday.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 07-02-2008, 01:12 PM
99ssleeper's Avatar
single adjustable or double adjustable.
if they have one **** then they are sa's. the bump (compression) is fixed and the rebound is adjustable. set them to full soft (-) for the track so the frontend can rise and if these are the r-series they should hold the nose up for quite a while before it settles back down. the f series are the street shock and will act the same but it has different valving.
Old 07-02-2008, 01:15 PM
99ssleeper's Avatar
edit...im assuming drag racing...
Old 07-02-2008, 01:28 PM
thanks yea its for the track this weekend i just got these last week on a roller i bought along with a strange 9in setup
thanks again for the help
99ssleeper was i tolerable?
Old 07-02-2008, 02:01 PM
99ssleeper's Avatar
borderline
Old 07-02-2008, 02:02 PM
BMR Tech2's Avatar
Good luck!!
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Quick Reply: qa1's
