Ring gap? Diamond forged/blower motor
Old 08-20-2003, 04:23 AM
blu00rdstr's Avatar
Default Ring gap? Diamond forged/blower motor
Could someone tell me ring gap for Diamond forged pistons in a blower install?
I've heard .035 on both, I've read .015-.020, and 2nd ring gap is 1.5x top ring.
Does blower make a diff? Forged pistons?
Old 08-20-2003, 08:05 AM
LOnSLO's Avatar
Default Re: Ring gap? Diamond forged/blower motor
.035" sounds way high. You will be fine with the .015 to .020 gap.
Old 08-20-2003, 08:14 AM
Vents's Avatar
i think with a blown application i'd defiantely call diamond. Chris is absolutely excellent to deal with and im sure he could tell you anything you'd want to know.
Old 08-20-2003, 08:39 AM
AP-Engineering's Avatar
How much boost are you planning on running? If you are around 10-12 pounds you can get away with .018 on the top ring and .020 on the 2nd ring. If you are running more than that for boost then I would go up ion gap accordingly. Running .035 for gap would be a lot. You would have a lot of blow bye with that much gap!!
Chris Gelineau
Diamond Pistons
877-552-2112 toll free
Old 08-20-2003, 03:21 PM
theblur98ss's Avatar
On my diamond pistons the gap was .050. My builder called diamond and they said as long as it was under .060 it wasn't a problem.
Old 08-20-2003, 03:38 PM
The under .060" was on the oil rails, not the compression rings. If you ran that much gap you will end up having a lotof blow bye.
Old 08-20-2003, 09:53 PM
blu00rdstr's Avatar
Thanks Chris! That's exactly what I'm looking for, I am aiming for 12psi or whatever I can get away with using 91 octane. I installed the oil rings. No need to check those, right?
I test fit the 2nd and 1st rings in the cylinder and the ends overlap. Is that normal? The bores were opened up with a hone to get the proper clearance for the pistons, but the bores are still too small for the rings.
I searched the bay area for a piston ring gap grinder, no luck. So I'll gently scribe and file ring ends tonight.
Old 08-21-2003, 03:53 AM
phenyxTA's Avatar
You can use a dremel tool with a sander attachment, they work awsome. Just do a little at a time.
Old 08-22-2003, 10:06 AM
Cann's Avatar
Chris, what ring package would you recommend for a big bore 20 pounds of boost application? TIA
Old 08-28-2003, 01:51 AM
blu00rdstr's Avatar
Um, slightly overfiled a top ring. Maybe two. Most of the top rings are .018, and the second rings are exactly .020. But one or two of the top rings got to .022, I measured (feeler gauge didn't fit), filed, and measured (feeler gauge can tilt in slot), cursed.
Am I OK, or should I ask Diamond to FedEx two top rings?
Quick Reply: Ring gap? Diamond forged/blower motor
