LT1-LT4 Modifications - 93 LT1 Z28 overheating?
yogibear19
07-02-2008, 03:47 PM
I have a 93 LT1 Z28. It has new water pump, hypertech 160* therm., both fans are on a toggle, full radi., shroud is in place. Most threads I find have been saying overheating while going slow or at a stop. Well mine is odd b/c it overheats bout 3k RPMs or while cruising with the AC on. Any help would be greatly appreciated. Thanks in advance. Robert
connexion2005
07-02-2008, 03:49 PM
Did you bleed the system after all those installs? If not run the car at idle with the cap off of the radiator until the car has completely warmed up enough for the thermostat to open up (watch your temp gauge to the point it stops heating up and actually stays there or cools a bit). With the cap off it will allow bubbles (air pockets) to rise up and bleed out the resoirvoir. If not properly bled the air pockets can cause big problems.
yogibear19
07-02-2008, 04:05 PM
Yeah we bled the system at the hoses. As soon the screws were opened we got a steady stream of coolant.
TXFORMULA
07-02-2008, 04:13 PM
did you wait for the thermostat to open? and what kind of waterpump? stock or electric?
connexion2005
07-02-2008, 04:18 PM
+1 You have to make sure the thermostat has completely opened...
Dadic 78
07-02-2008, 05:42 PM
How old is that rad? When I replaced my rad, my cooling efficiency increased 10x.
I'd check the system for air pockets, but if that's a dead-end, consider the rad.
yogibear19
07-03-2008, 01:05 PM
Stock water pump, can't remember weather the threm. was open are not, the rad. i think is the same age as the car.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
