hotchkis vs. bmr springs
once my transmission is fixed, i want to go ahead and get either the hotchkis or bmr 1'' lowering springs, and was just wanting some input on the two
obviously if funds allowed, i'd be completely upgrading everything with a koni/strano combination, but that's out of the picture.
i've rode in a lt1 lowered on hotchkis, and thought the ride was very reasonable, and it looked awesome.
thanks
thanks
i used to have hotchkis on stock decarbons and the ride wasn't bad at all. i cant comment on bmr springs though as i dont have any expereince with them...
i currently am debating about another set of hotchkis or dms. i would prefer a little more drop than the hotchkis 1"...
DMS Springs LS1 98-02 (front)325-630 (rear)95-160 (drop)1.30"
LS1TECH Sponsor
You can still run my springs.... The fact I prefer Koni's is the case with any of those springs. My springs are 550 front, 150 rear always have been and never have we changed our published rates to suit public opinion.
A few here have run them on stock shocks and reported the ride to be about the same. I can't really tell you, because I think the stock ride sucks so I change shocks before I usually worry about springs (or at the same time). In fact I had a man change from Hotchkis to my springs and told me he felt the car rode better (and he had Koni's on with both springs) because the car didn't get on the front bumpstops as hard/quickly.
And that is a big reason why we run the rates and heights we do.... I don't think the Hotchkis are quite firm enough in front overall. The BMR springs aren't terrible as I do think there are worse springs. But the rear rate IMHO doens't need to be 170. Stock is 115, and the max on a 1LE spring which I felt was a bit too stiff was 180. And FWIW, the more rate you have the more shock you need to control it. Overall you are talking about 3 similar springs, but not the same. In the end, mine are the lightest, the most proven to handle, and I feel the best rates. Strano Springs are the newest set, I got to try a zillion other rates, heights, and off the shelf spring sets. I wanted my car to work the best it could and settled on rates and heights that make the car the easiest to drive. Then I incorporated that info into my spring sets.
FWIW, I sell Hotchkis too. I don't sell BMR, and readily admit that.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
I should add on stock OD tires: Measuring ground to fender results in numbers of about 26" front, 26.75" rear on LS1 cars. About .25" lower on LT1's. More often than not we drop the nose about 1", the rear 1.25".
__________________
LS1Tech Premium Sponsor
Buy the Konis if you can afford them. If not, the Tokico shocks are a very good bang for the buck. Either shock works well with the BMR springs.
The BMR springs are made from high tensile chrome silicon steel. This is the same spring material used by many NASCAR teams. This material "springs" back to its original shape quicker than most other types of steel.
The BMR springs cost $229.95. Strano Parts sell the Hotchkis springs for $249.99. They sell the Strano springs for $275.
If you search the internet, you will find lots of customers who are very happy with their BMR springs. BMR springs are Proudly Made in the USA. We have them in stock and we offer SAME DAY SHIPPING.
If you have any additional questions, please call Lee Spicher at BMR. He is the best suspension tech guy in the LS community!!
I would go with the BMR springs. One of my good friends is running the BMR springs, and I love the stance and ride characteristics of her car (for a non-coilover setup).
I am running Strange D/A coilovers, 300# front and prokit rears (too low, **** quality) so I'm going to give Lee a call today about ordering a rear set of their springs. Lee has helped me extensively with upgrading all of my suspension, and answers any questions thoroughly.
Thanks Lee!
Thanks Lee!
Did you guy's check out this months contest
https://ls1tech.com/forums/suspension-brakes/947879-hook-bookoo-bmr-nitrous-outlet.html
Springs and an adjustable panhard bar FREE !!!!!!
They said it's a random computerized drawing..theres usually alot of entries, I'm not sure what your odds are, but I'll never go to a casino with you
thanks for all the input, everyone
im still waiting to get my transmission back from D&D, so i still have some time to think. idealy, i'd like to pick up a set of used springs, as i've seen some go for very reasonable prices
I think the price difference you listed is quite misleading, although it was a while ago you posted this.
