What can I expect for a 1/4 time?
I am running the SS saturday at a 1/4 track in Orlando. I am not sure how it's going to run. All it has is 3.73s and it will be getting a tune before I go. I just did plugs, wires, fuel filter, air filter, trans flush, oil change, etc. So the car should be good to go. I am hoping for 13.6 or lower...any input?
I used to run at that track just watch it the track prep there can suck. But ya stock you should be able to run under a 13.6 and you have gears, if you can drive you should be able to get low 13's...
