Imput bearing Issues?
Input bearing Issues?
Hello dudes. Im new here and new to the ls1 community. I have always been a turbo japcar guy in the past but have moved into a 88 10th anniversary rx7 turbo 2 with a 2001 LS1 T-56 6-speed out of a WS6 Trans Am.
My issue here is, in the past when ive seen front wheel drive and rear wheel drive cars with input shaft bearing issues the bearing is noisy and makes a grinding sound when the clutch is disengaged in gear or neutral. Once i push the clutch in, the bearing quiets down (as the input bearing stops spinning id assume). My question is, does this sound like a proper diagnosis of this issue or am i forgetting to look someplace else. The noise sounds right around the shifter so id assume thats right in line of where the input bearing is correct? Is this a common item to go out? I know in countless fwd setups, when the clutch is fairly abusive in engagement, it sometimes causes the bearing races to let go and you loose ball bearings from the input bearings on older transmissions, generating the sound. Are these the same way and do they wear out, since this is 7 years old, or is this something thats could be caused by something thats not in spec? Any help or suggestions would be appreciated.
The only mods are as follows.
All Stock, has all emissions removed
only running an Alternator, with Kaltech belt Tensioner
JTR Longtube Headers
Transmission:
Spec stage-3 clutch and flywheel
5.0 Pro Short Shifter
Transmission:
Sounds like it might be a bad pilot bearing. These cars have bearings from the factory and it's obvious if they are damaged. Mine acted like that when it failed. It's right at the back of the engine block but the sound would probably be loudest at the shifter, as you've observed. Time to pull that transmission. I'd check the throwout bearing too while you're in there.
I'm having a similar issue as described by original poster. To add to his original post is there anywhere that you can buy JUST the throwout bearing. I checked at SummitRacing and its almost 400 dollars. A premium replacement clutch kit in full is only 300.
Post on the parts needed site. Lot's of people have extras. BTW you should be able to get a slave cylinder (which comes with the TO bearing) for around $100. NAPA carries them and also the pilot bearings.
Man i expected to have to pull it. i guess its time to pull it and put another block in there while im at it
LS1TECH & Trucks Sponsor
Either one will work fine
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
