Any performance advantage w/EGR Delete
Old 07-03-2008, 03:37 PM
bobdec's Avatar
Default Any performance advantage w/EGR Delete
Ok,I have a street driver '94 Z28 see sig. below. I've drove it 3 months with EGR turned off and the past 2 months with it enabled . Honestly I can't feel any difference. Since it only kicks in between 900 and 2300 RPM it's off when you really need power anyway. I know the heat cooks the rear intake manifold oil seal, it blackens the inside of the intake manifold and the engine looks neater without the extra hardware. But for someone concerned with dumping NOX into the air is there actually a published performance gain that warrants disabling it ??
Old 07-03-2008, 04:18 PM
nighthawk15's Avatar
No gain at all performance wise. The reasons to remove it are:
  • Clean up the engine bay.
  • Fix the intake manifold heat issue.
  • One less thing to be a pain in your *** when it breaks.
Old 07-03-2008, 05:09 PM
Formula350's Avatar
And if it does break, it CAN cause some fuel economy issues if it sticks open. Don't think it'll cause any noticeable performance loss if it does though.
Old 07-03-2008, 05:12 PM
Revelation Z28's Avatar
then theres the rumor of blowing your head gasket because our cam doesnt have enough overlap to bleed the cylinder pressure.
gotta love the internet.
Old 07-03-2008, 05:42 PM
Formula350's Avatar
haha I remember that post. I told him that I guess I'll be looking to blow my gasket any time now since I tuned mine out completely and I'm still fully stock block.
Old 07-03-2008, 06:11 PM
I8ASaleen's Avatar
Yay. No performance difference.
Old 07-03-2008, 06:17 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Talking
WHAT.??? People lie on the WEB.?????
Old 07-05-2008, 12:16 AM
Formula350's Avatar
Nope.
(Couldn't resist)
Old 07-05-2008, 09:36 AM
bobdec's Avatar
Thanks for the responses, bottom line - no performance hit if on and functioning correctly. My next mod is going to headers, but here in GA I have to pass sniffer test and have the EGR working. If EGR has to be there to get tags and possible future sale of the car I may as well buy headers with the emission fittings, put up with the known negatives and keep it activated.
Old 07-05-2008, 06:27 PM
Formula350's Avatar
My EGR is still in place, I just removed all the vac lines for it, and it's tuned out. Some people have passed w/ it tuned out. There are cams that also mimic what the EGR does, so you could get provisionless headers and that cam and have a high probability of passing, of course with a tune for the new cam.
Old 07-05-2008, 07:12 PM
CamaroRacing12's Avatar
weight reduction baby!
oh and on the internet im a straight 19 year old male from mass.... in real life im a gay man that likes to creep on lil boys in the darkness
Old 07-06-2008, 02:44 AM
im about to make some block off plates for mine out of the sheetmetal i cut out of the car's rear for the fuel pump access
my flange for my LTs was a factory defect, and the tube was a bitch to get in. i had to crimp it to get it in and it leaked.
im still a little paranoid about the headgasket rumor and leaving the solenoid so i wont get an SES
Quick Reply: Any performance advantage w/EGR Delete
