How much oil does the Moser 9" take?
Old 07-03-2008, 04:24 PM
Schantin's Avatar
Exclamation How much oil does the Moser 9" take?
Can't get the plug off the center section.....and I know not to fill to the top of the cap on the housing
So.....how much oil should I put in this puppy? Need info quick. She's all done otherwise.
Thanks.
Old 07-03-2008, 04:30 PM
Schantin's Avatar
OK...answered my own Q. Searching "oil capacity" gave me nothing. Searching "capacity" answered the question......
3qts (approx )
Old 07-03-2008, 08:40 PM
EPP
EPP's Avatar
Just a little over three quarts, probably 3-1/8 to 3-1/4. Bob
Old 07-03-2008, 10:49 PM
LSX Mechanic
Damian's Avatar
I run almost 4 qts in the ones I set up. No problems.
Old 07-04-2008, 12:20 AM
roy
roy's Avatar
I found that anything over 3 qts in the Moser 9 tends to spit it out through the vent line. Get the plug out and make your self a L shape coat hanger tool with the base of the L for measuring no longer than 1/4 inch. Use this to set your fluid level to 1/8 inch below the level of the plug fill hole.
Old 05-07-2010, 09:11 AM
Camaro Junky's Avatar
I am having a problem with oil coming out of both axle bearings. I thought it was a bad Napa axle bearing, but now I am seeing some gear oil come out of the Moser bearing now.
I put 4 quarts of oil in the M9. When I pulled the left axle there seems to be about a 1/4 of an inch of oil in the axle tubes. This has to be too much oil.
Can I drain the oil out until there is almost no oil in the axle tubes? Just seems odd that oil started leaking when I put 4 quarts in...
Old 05-07-2010, 12:41 PM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
The oil fill is located on the left side of the housing on the Moser 9 inch rear end. It is relatively close to the torque arm bracket. Fill the rear up until the fluid starts to seep back out of the fill hole. It should only take a little over three quarts of gear lube.
If I were you I'd temporarily remove this fill plug. The M9 also has a plug in this same location, as it is in the third member. If you have too much in there, it will drain out until it reaches the correct level. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Quick Reply: How much oil does the Moser 9" take?
