rear tires
Old 07-03-2008, 05:49 PM
cad2k3's Avatar
Default rear tires
will 315 tires be ok in the back of a 99 TA? i dunt want any rubbing
Old 07-03-2008, 06:12 PM
OEM_TA's Avatar
It will depend on your wheel size and offset.
Plus you most likely will have to roll the fender lips and use a BFH in a spot or two.
The general consensus is that the 315 Nittos are a bit narrower that some other manufacturers.
I was struggling with an issue along those lines.
Got lots of info from many folks, check out this thread...maybe it will help you
https://ls1tech.com/forums/showthrea...428&highlight=
Old 07-03-2008, 06:40 PM
Danny2tek's Avatar
No issue's here. Click my sig for pics
