affordable water pump
The EWPs are a good way to go because they free up some power. I have the Meziere but I am sure the CSR is good to. Both require some modification if I am not mistaken. With the Meziere, the fan shroud has to be cut. With the CSR, the water pump housing has to be "notched" for the pump to fit. Either one is not difficult. And where it says you have to use a hydraulic press to press the old gear out of the housing, a hammer will work just fine. When I did mine, I painted the water pump housing black to match the EWP and it came out nice.
As far as where to get them, I got mine from WS6store but many of our sponsors will have either one. Good luck.
