service engine light comes on and off.
Old 07-04-2008, 09:23 AM
3rdDegreeBurns's Avatar
Unhappy service engine light comes on and off.
So I had this light come on and then checked the codes and it had 2 showing up which were the same. This is the results from the odbii website.
DTC Description
P0174 Fuel Trim System Lean Bank 1,2
VIN Digits 2
Manufacturer 3
Division 4
Body 5
Series 8
Engine 10
Year
So I changed all the 02s out and erased the codes and now the light is back on and off, checked the codes again last night and same code. Any ideas what to look at next? A couple people I talked to might think it is an air leak since it's showing up lean. Now only one error is showing up P0174 being bank 2 being lean.
Old 07-04-2008, 06:48 PM
joshp14's Avatar
Check and double check all vacuum lines. P0174 or P0171 is almost always a vacuum leak after the MAF sensor. I have had MAF cause this code too....but check for vacuum leaks first.
Old 07-04-2008, 11:42 PM
ok will check this tomorrow morning any certain advice as to how to tell if the maf is causing the problem?
