Any Bluetooth adapters in place of CD changer
I've got an ATT tilt with 4gig's of music and a 2002 trans am with the monsoon system. I've removed the CD changer years ago, is there a way to adapt an input with either bluetooth or hard cable to the wires that lead to the changer? Sorry if this is a newb? I searched "bluetooth" and read the stickies and didn't find what I was looking for.
Copy & Paste Moderator
You can convert the CD Changer port to RCA AUX-IN using a GM9-AUX.
That will allow you to connect any AUX device with RCA output connections (or a 1/8" headphone jack adapted to RCA with an adapter cable.)
I don't know much about Bluetooth retrofit devices, but if any have RCA or 1/8" output, then you can use the GM9-AUX to send the sound through the car's speakers, but you'll still have to use the microphone of the retrofit device.
