Sfc
Old 07-06-2008, 09:03 AM
twitchtwice's Avatar
Default Sfc
give me some ideas for welding in my sfc's.
i plan on putting a jack underneath it just to put a little pressure on it to make a good weld. is that a good idea?
Old 07-06-2008, 04:01 PM
Medic/Z28's Avatar
Make sure you grind off the power coat paint on the SFC and grind the surface on the actual frame for a good clean weld. Make sure you have two jacks on each end. I also welded a section of the middle to the frame. Didn't want it to be weak.
Old 07-06-2008, 11:29 PM
Formulated's Avatar
I don't know if you're doing this on a lift, or on stands. However, try to have the suspension loaded as much as possible. Any chassis deformation present when the suspension is loaded, and static, should be present when installing the connectors.
Old 07-07-2008, 07:23 AM
leadfoot4's Avatar
I agree.
You don't want to jack in any other deformation or stresses when you weld in the connectors.
Old 07-07-2008, 08:07 AM
yea we have a lift in our camaro garage. so it will be a loaded suspension. i plan on just jacking light pressure on the SFC just to make sure its got pressure on it when i weld it in.
Old 07-07-2008, 09:10 AM
DRGnFLYZ28's Avatar
I like that idea. Just enough to make sure it's tight fitting. If they are like my BMR's, they bolt on to the rear control arm housing so you wouldn't need it but it would have been nice to use your idea on the front part.
Also, don't forget the undercoating or paint to match to prevent rust.
Old 07-07-2008, 12:07 PM
WS6addiction's Avatar
That's the way I did mine. You want just enough pressure to hold them in place while you tack them in. Then remove the jack to weld them.
