speedo and start-up?
When I start up my SS the speedometer goes all the way to like 100mph then slowly back down on the initial start-up...along with the tach! The tack should move obviously but why the speedo; I never noticed this before.
did you do anything with the cluster recently??
I know whenever I take mine out and put it back in it will do that. It is a one time occurance though. It is def related to your cluster loosing power and regaining it again. Take it out and check connections or your fuses.
No, I haven't done anything to the car, other then replace the door speakers with OEM units. I don't recall the car doint this before, but I will check the odometer tommorrow to see if it resets.
Your battery is about to die on you. I had an EXTREMELY similiar issue with my car.
Is it a little hard to crank? Do you have a multimeter? Measure the standing voltage without the car running. If it's in the 11V or less, then the battery is on it's last legs. A cell is on it's way out.
