Metric Thread Adapter For Temp Sender
I have been looking but have not came across the correct adapter just yet. I need a little guidance guys. Where to find?
I want to put my stock 1970 Temp sensor in the rear hole in the passengers head. The stock thread pitch is 1/2 X 14 NPT.
Any help on how to get this temp sensor in the head without drilling and tapping is greatly appreciated.
Thanks,
Eddie
Thanks,
Eddie
There is a heater plug in the block just below the head temp sensor. You can drill that out and tap it for a sender.
Don't think there is a way to get a half inch sensor in that little metric head hole.
Do a search on here, I saw a thread where a guy drilled out an existing sensor and inserted the one going to the original guage. I think he did this for his 1st Gen Camaro. It might be in one of the permanent stickies....
I believe that was for an oil pressure sender, don't think that will work to get a temp sender from a 70's car in it, the sender is just too big. Like others have said, your probably going to have to drill and tap. It's not that difficult, providing you can get to it. Might be a little tough if the engine is already in the car though. Anyway, a little grease on the drill and tap will keep the metal shavings from falling into the coolant passages.
I made the mistake of running a manual temp gauge, Autometer, which is a similar sending unit, big probe. I ended up with $45 worth of adapters, that put the probe about 4-5 inches from the head. Certainly not the ideal setup. It showed 20*-30* different than the electric sensor for the BS3. It was terribly ugly too. I ditched that for a full sweep electric gauge. I got all the adapters at a local industrial hyd. supplier. Way too much work and money for results in my application.
Suggest you work with the local part store guy to find out what ohm reading your factor sender is and see about finding a smaller (1/4" or 3/8" NPT thread) sender that can work with your factory gauge. Once you find one, you can either get the adapter or drill and tap the head.
Even if you were to drill and tap the pasenger side head for your 1/2" sender... The Sender will be very close to the Exhaust Manifold and may not give you enough room to thread the sender in. I am not even sure that once you drill and tap, that there will be enough of the head left to be safe (too thin of a water jacket need to the exhaust port or threaded part of the head to be safe).
The thread you are working with is 14 mm X 1.5mm pitch. This is a straight thread, not NPT (national pipe thread which is tapered). I cut my sending unit down in a lathe and re-tapped 14X1.5....Works great. Any machine shop should be able to do this for you. If you have an old sending unit similar to the one you will be using just cut it apart with a hacksaw and see if you have enough meat to do this.
I think you may be able to find a sender to correctly match the ohm range needed for your gauge. e-gauges.com lists several that perhaps may work. If you can match one up that has a 1/8 NPT thread, then adapter forthe 12x1.5 thread in the head are available from them as well. It would greatly simplify the task.
Andy1
Andy1
It is 12x1.5
Here is a pic of a sender adapted to the block heater plug. The block plug was drilled out and tapped with a 1.2-14 NPT. The other adapters are to fit a Datsun sensor.
sawzall wielding director
The sender is 12mm x 1.5. I think your sender might be the same as the one for my El Camino as it was 1/2" NPT. And I cut it down in a lathe and rethreaded it. You could probably just spin it in a drill and use a file to cut it down. There should be a couple pics on my fquick account of the rethreaded sensor.
